Changing Nameservers
Hi, I recently hosted my website on Profreehost and used their domain unaux.com. I want to change its nameservers so that I can use Cloudflare's nameservers to get SSL. But I am not able to change them. @badbot Please help.
Howdy, Stranger!
It looks like you're new here. If you want to get involved, click one of these buttons!
Hello @Divit_745
You cannot change the unaux.com nameservers as then it will affect ALL domains.
Plus, if you use the ProFreeHost nameservers WITH the Cloudflare nameservers, it will tell you to remove the ProFreeHost nameservers or Cloudflare won't protect your website.
I think there is a workaround, but I do not know.
