display error problem
how to solve enable display error problem?
please check my domain :verifybadge.unaux.com
Howdy, Stranger!
It looks like you're new here. If you want to get involved, click one of these buttons!
It seems like your site requires login credentials. Failing to login gives the issue you mentioned.
You can enable display errors using the panel's
Alter PHP Config
option.
