Not secure to access control panel
edited November -1 in Support Forums
hello
I can not access the control panel because it shows this problem "Because this form is being submitted using a connection that’s not secure, your information will be visible to others.
    There should be a "Continue Anyway" button; hitting that will allow you to proceed.
    If you're uncertain, you can login manually to the panel by visiting https://cpanel.liveblog365.com/ and entering the username and password that are show in the "FTP" section of your client area.
