Error after installing moodle script !
edited November -1 in Support Forums
I need help, i created a New a/ c that is www.fliplearn.ezyro.com and installed moodle script. But the problem occur (Fatal error: $CFG->dataroot is not configured properly, directory does not exist or is not accessible! Exiting) when i tried to access it.
Please help me to fix it.
Thanks in advance
    @badbot said:
    Hello
    Did you use the control panel to install or the downloaded script installer from the moodle website? Were you asked for a file path to the root directory at any time?
    8
    I used the control panel to install it
    Thanks very much
    @badbot said:
    Hay
    You have to set the data directory to /htdocs/moodledata at install setup. So you will have to remove the current install.
    Don't worry the directory /moodledata (or what ever you name it) will go 403 if anyone navigates to it on a web browser. You can still set /moodle30 directory to /.
    Hay
    I tried to follow your instructions, but there another problem, can you help me ? . The error is
    "This page isn’t working
    fliplearn.ezyro.com redirected you too many times.
    Try clearing your cookies.
    ERR_TOO_MANY_REDIRECTS"
    Thanks in advance
