Nameservers Help
@smithtasticness said:
Hello,I'm a bit confused. Initially I was told to use ns1.byet.org etc nameservers but then on creating and going to cpanel it says the nameservers are ns1.unaux.com etc.. Which should I be using?
Thanks.
Use whatever of the two you want. They point on the same IP addresses.
