Unable to use remote applications
I get aes.js javascript errors when trying to post data into a form. How can i remedy this issue?
Full error from program:
function toNumbers(d){var e=[];d.replace(/(..)/g,function(d){e.push(parseInt(d,16))});return e}function toHex(){for(var d=[],d=1==arguments.length&&arguments[0].constructor==Array?arguments[0]:arguments,e="",f=0;fd[f]?"0":"")+d[f].toString(16);return e.toLowerCase()}var a=toNumbers("f655ba9d09a112d4968c63579db590b4"),b=toNumbers("98344c2eee86c3994890592585b49f80"),c=toNumbers("ccbb15ca7e3cf5af5bb7cb0fa4f45ca9");document.cookie="__test="+toHex(slowAES.decrypt(c,2,a,b))+"; expires=Thu, 31-Dec-37 23:55:55 GMT; path=/"; location.href="http://testdatabase.unaux.com/register.html?i=1";
UnityEngine.Debug:Log(Object)
c__Iterator0:MoveNext() (at Assets/PHPLogin.cs:42)
UnityEngine.SetupCoroutine:InvokeMoveNext(IEnumerator, IntPtr)
I created a test site to practice doing this but it looks like some kinda javascript file from unaux is stopping me...any workaround?
Howdy, Stranger!
It looks like you're new here. If you want to get involved, click one of these buttons!
I even tried to just mimic the cookie part:
www.SetRequestHeader("Cookie", "\"__test = \"+toHex(slowAES.decrypt(c,2,a,b))+\"; expires = Thu, 31 - Dec - 37 23:55:55 GMT; path =/ \"; location.href=\"http://testdatabase.unaux.com/register.html?i=1\";");
but it does not fix the issue.
turns out this is a bot security thing...usually sites have a way to turn it off but it looks like if i do that it would not be the best solution either. My only option would be a remote mysql server with a static which would cost money hmmm..
@Zizzy
You can use Apache rewrite to remove file extension, (?id=1) without blocking the tracking cookie.
true path:
Use htaccess to remove file extension.
htaccess file:
http://badtech.gq/
Use CloudFlare by either activating it from the control panel or by transferring your site to them.
